Ansbacher
Feb 25 2017, 11:14 AM
Are both tapered screws that retain the shift rod (one near the firewall and one near the transmission) supposed to be the same screw? When I did my shift rod bushing job yesterday, I noticed the screw near the firewall looks like what is pictured below, but the one near the transmission has a hex head that takes a socket. I want to buy new screws but I only see ones like below, so am assuming they are supposed to match? Input appreciated. - Ansbacher in Tampa Bay
TheCabinetmaker
Feb 25 2017, 11:21 AM
That is the correct screw. They are said to be a one time use screw. I just use blue locktite. I've never had one come loose..
Ansbacher
Feb 25 2017, 11:25 AM
Cabinetmaker: By correct do you mean for BOTH ends of the rod?
QUOTE(The Cabinetmaker @ Feb 25 2017, 12:21 PM)
Krieger
Feb 25 2017, 11:41 AM
They should be the same. Sounds like somebody might have stripped the threads and came up with a home brewed fix. They drilled and tapped a bigger hole and fit a bolt they tapered. Take a picture. The rear piece is easy and inexpensive to swap out.
rhodyguy
Feb 25 2017, 12:09 PM
Just replace the rear coupler if the threads have been oversized. JWest, member vendor, sells a tapered screw that incorporates a jam nut. No Loctite needed for reuse. Unless you've changed it out recently plan on a new ball cup bushing for the coupler.
IronHillRestorations
Feb 25 2017, 12:50 PM
I've got one of those square head taper screws, but I only use it for my shift rod jig.
The one in the pic is the right one, and it should have a little dowel of nylon inserted in the threads to hold it in place. Alternately you can do as Curt said and a small dab of blue locktite is just as good.
MartyYeoman
Feb 25 2017, 03:46 PM
Use these with safety wires. No worries.
Ansbacher
Feb 25 2017, 04:28 PM
Thanx all for the goldmine of information. I know what to do and need now.
Ansbacher
