QUOTE(Larmo63 @ Feb 25 2017, 12:14 PM)
The back pad slides UP into those four clips (two behind each seat) and if you get it this far, you should be able to screw in the lower screws.
Try using an awl to "source" these holes. This should be pretty easy once you get the pad into place.
It only fits in one way.
Thanks found them! Now I just fhave to find the correct bolts but luckily those are pretty well marked. Thanks again that's saved the day!
