76 2.0, 118,000 miles, engine runs perfectly, all equipment functioning, (thermostat, auxiliary air regulator, no vacuum leaks, but engine runs on for several seconds or more after shutdown. The motor does have a Crane Fireball ignition system. From what I have read here, and ruling out a vacuum leak and an unlikely leaky injector as the cause of the run on, the Crane ignition is often mentioned in the forum as a possible cause of engine run on. If the Crane ignition is the cause, the fix mentioned is to install a diode on the lead to the generator light. I am going to follow these instructions at this link:
http://www.mgexperience.net/article/mgb/ignition-run-on.pdf
I have ordered the diode named in the article and I just wanted to check in this forum that my plan is sound before I do the diode installation. I'm not sure if this will fix the problem, but I don't see a downside to trying this next. Does anyone else have a comment on this next step?
