QUOTE(Mike D. @ Mar 1 2017, 06:22 PM)
Aux Air Valve connects to a wire coming from the #12 pin on the engine wire harness from the engine bay relay/fuse panel. Can't remember what color. It is powered by the fuel pump relay. It does not come directly from the CPU harness (all white with numbers)
Thanks Mike, at the risk of asking a dumb question, but to be sure I'm at the right connection, where exactly is the engine bay relay fuse panel, under the cover next to the voltage regulator? Is the #12 pin marked with a number or some other way to identify it? Also, any idea why the brown negative wire lead, only grounded when car is on, exists at all in the area of the throttle body?
