I've only done a Beetle before, but planning on blasting my 914 at some point soon. I have a Harbor Freight blaster, it's the cheap small red one. I've used coal slag before but the problem is it leaves a really rough texture on the metal after making it hard to wipe down prior to primer without leaving lint fuzzies. I've had better results with glass abrasive (the brand I'm using is called Clean Bite I believe). I get it from Northern Tool and it's about $8-9 per bag. I have 500 pounds ready to do my 914, will find out if that's enough.
Doing it yourself is certainly an all day affair and makes a big mess. I've toyed with the idea of paying someone to blast it more than once, but in the end can't get myself to pull the trigger.
Another idea to look into is the "wet blast" attachment for a pressure washer. It's a siphon feed, but supposedly does pretty well.
Here is a link. Of course, then you have to spend more $$ for a chemical to keep it from flash rusting, like Hold Tight 102.
