QUOTE(bdstone914 @ Mar 2 2017, 06:20 AM)
QUOTE(aggiezig @ Mar 2 2017, 12:28 AM)
Any trick for loosening up the seat hinges? I've cleaned all the rust off and soaked them in penetrating oil for a few days, but they are still stiff as can be. Does anyone know if the pins can be driven out of the hinges? I could clean up the pins and re-install with my vice.
Anyone have a trick up their sleeve for these?
Bolt the seat frames to them and work back and forth. They should be stiff but movable.
Short of cutting them out, Bruce is probably right. When you bolt them back on to work them, don't connect the front part. You get a wider range of motion. Or use big vise grips, one hinge at a time.
Once installed, the range of motion is really ZERO. Once you get your seat set like you like it, just don't let anyone know that they are (slightly) adjustable.
You might look for other penetrating fluids. I like to use Sili-Kroil. Before I found that, Blaster was my go to.
http://www.kanolabs.com/ Love their moto.....
"Used by 480 of the Fortune 500 companies!"
