smrz914
May 3 2005, 09:02 PM
I played around with photoshop a little bit. I hope 914RS doesn't mink I used his picture.
Anyway, instead of having a tube go from the ear to the firewall, I thought that one could take some sheetmetal and create a shelf. I don't thin this will work for /4 but it might for converted cars. I thought a cross section might look like
_____
|_____\__________
Would this be strong enough? Just seeing if there is a nice way of doing the brace. So It would be like having another shelf. I don't know how low the engine mount goes but I think one could work around that. On the ear the attachment point would be pretty low and be able to handle movement better. On the firewall site it would attach to the back edge of the floorpan.
Series9
May 3 2005, 09:08 PM
As long as the box tubing is substantial enough, I think that would work fine.
smrz914
May 3 2005, 09:18 PM
In that case the question becomes, what is substantial enough?
Porsche Doc
May 3 2005, 10:06 PM
Hey smrz914,
Here is the way we do it to all our hot rods and race cars.
We box the almost all of the suspsion console with 12Ga like the GT stiffing plates.
The ReaL week point is the lower section of the ear.
It takes the most load. The tubing is good to add also
Here's some pics.
Porsche Doc
May 3 2005, 10:07 PM
another
Series9
May 3 2005, 10:09 PM
QUOTE (smrz914 @ May 3 2005, 08:18 PM) |
In that case the question becomes, what is substantial enough? |
.125" wall and .75" x 1.5" box tube would be the minimum I would use in your design. That being said, I would still want to see it in person before I made a final judgement.
John
May 3 2005, 10:46 PM
I did my race cars similar to Porsche Doc. I fishplated the console and then added tubing. My tubing goes through the firewall and ties into the cage.
The shelf idea is interesting, but what are you attaching it to at the front? (the floorpan?) You may need to add some strength to that if you tie in there.
To add stiffness to a structure, your anchor points must be substantial, or you are wasting your time.
If you decide to go ahead with the shelf and rectangular tubing, I would consider adding some drain holes to the shelf.
just my $0.02
Brett W
May 3 2005, 11:12 PM
Don,
I didn't see you and Charles at the Mitty. What happened?
smrz914
May 3 2005, 11:14 PM
Thanks guys I'll have plenty to mull over for a while. I'm just making plans for my project. Porsche Doc, did you add metal to where the trailing arm bolt goes through the ear, possibly requiring a longer bolt, or was that left the stock thickness, and metal added around where the nut would be?
Jeroen
May 4 2005, 06:51 AM
here's what I'm planning to do
weld a piece of 2" tube around the nut
then tie braces to that (braces will be weld to both the 2" piece of tubing as the susp.ear itself)
All the cracks I've seen are either at the nut or just above it
I feel the braces pictured above don't reinforce that area
This should
JWest
May 4 2005, 07:13 AM
QUOTE (Jeroen @ May 4 2005, 07:51 AM) |
weld a piece of 2" tube around the nut then tie braces to that (braces will be weld to both the 2" piece of tubing as the susp.ear itself)
All the cracks I've seen are either at the nut or just above it I feel the braces pictured above don't reinforce that area
This should |
Watch your clearances there Jeroen - that area is close to the engine.
Jeroen
May 4 2005, 07:20 AM
QUOTE |
Watch your clearances there Jeroen - that area is close to the engine. |
I know, it's gonna be a tight fit
The 2" tubing will only be about 1/2 an inch deep
andys
May 4 2005, 09:45 AM
When adding structure to the ear and extending it to a remote location, any flexing in the chassis that is realized between those to points may cause undue transfer of loading to the ear. This may cause the cracking/failure you're trying to avoid in the first place. A localized structure that spreads the loads I would think to be a better solution. If you have a full cage, then this may not be an issue.
Andy
Porsche Doc
May 4 2005, 11:12 AM
QUOTE (Brett W @ May 4 2005, 12:12 AM) |
Don, I didn't see you and Charles at the Mitty. What happened? |
Hey Brett Man,
We did't get to go. Charles is the PCA SMR region Pres. and he had the to go to Spring Fling thing they have.
BUT we will be back next year. I was told it was a big turn out.
Hey smrz914
We did not plate a the section of the ear were it bolts. Take a good look at the pic and you will see.
Hey Jeroen
You are heading for trouble with your design. Like James said the engine is real close there.
If it has a six in it you won't get the valve covers off with out taking the engine out.
Brett W
May 4 2005, 12:11 PM
Yeah 400+ cars. The 914 crowd didn't really make a great showing. Most broke or also ran.
brant
May 4 2005, 01:16 PM
QUOTE (andys @ May 4 2005, 08:45 AM) |
Andy |
Sorry no pictures currently of my 4 cylinder car..
but Jeroen its nearly like your plan.
It works.
and does not create additional problems.
I know this because I ripped out 2 suspension consoles (NO RUST) before I did the bolt in brace.
and since that time with 8-10 years I have not ripped out a suspension console.
Yes it can be close for fitment, but that is the beauty of a bolt in brace. You simply un bolt it when you want to drop the motor.
brant
J P Stein
May 4 2005, 04:49 PM
QUOTE (Porsche Doc @ May 3 2005, 08:06 PM) |
Here is the way we do it to all our hot rods and race cars. |
I like the looks of this . To my of thinking, the lateral forces are the greatest and it happens to coincide with the weakest axis of the ear and since the damn things seem to rust from the inside out......I'm thinkin' of removing the entire inside half of the ear & fabing a 3/16" plate to replace it.
Jeroen:
I had to grind down my turbo valve covers about .3 in in order to clear the end of the pivot rod in order to get em' off & on.
The more "stuff" in the way the worse it's gonna be.
MecGen
May 4 2005, 05:13 PM
Hi
I followed a couple topics like this and got some real help. My experience has been that they break at the bolt hole across, then fold outwards to the direction of the fender. I wonder if Brants broke this way.
My research left me to understand that, if the ear is in good condition, its ok for almost anything on the street. If it is so-so but save-able, it should be re-inforced.
I just don't think the solution offered here has any real benifit for the street. I look hard at mods to preserve my car....still looking at it.
Later..
Joe
brant
May 4 2005, 05:44 PM
QUOTE (JoeSpark @ May 4 2005, 04:13 PM) |
Hi I followed a couple topics like this and got some real help. My experience has been that they break at the bolt hole across, then fold outwards to the direction of the fender. I wonder if Brants broke this way. My research left me to understand that, if the ear is in good condition, its ok for almost anything on the street. If it is so-so but save-able, it should be re-inforced. I just don't think the solution offered here has any real benifit for the street. I look hard at mods to preserve my car....still looking at it. Later.. Joe
Joe,
I want to agree with you regarding street use..
not all that necessary in my book.
and I should of added that both of my failures were on a track car not a street car
and finally, yes.. both of my failures started at the bolt hole...
The first time I thought it was metal fatigue becuase the car was 20 years old (although it had NO rust even inside)... but after we put in a brand new console and it failed in less than 1 year I sought a better plan.
That car is a -4 so the bolt in bar angles towards the center of the firewall. The console side of the bar bolts 1 inch away from the bolt hole
On the new race car the bolt in bars are similar, but with very different attatchments methods and it attatches 8+ inches away from the bolt hole with the bar running very straight forward to clear those valve covers.
On my -4, I reconverted it to a street car now. (although the motor and tranny are both currently blown) I reinstalled heat-exchangers, heat duct work, and all the stock bits right around the existing bracing bar.
In a month I'll try to get a pic of it.
brant
Andyrew
May 4 2005, 05:53 PM
Any more pics Jeroen?
This is an area I will be reinforcing at my next engine pull... (probably soon...)
And I want it to be able to hold the v8's tq on hoosers with rock hard suspension...
Probably get a good welder and helmet before this as well.. lol
Andrew
Brad Roberts
May 4 2005, 07:20 PM
Jeroen has a good idea. Something I rarely see is support running BOTH directions. He addresses this.
JP,
IF, I build another car for myself.. I will do exactly like you spoke: peel the top cover off the ear and weld in a scab plates.. then weld the "cover" back on. I do not like any of the tubes leading into the front of the ear. Most people use small tubing and all it does is crack at the point where they welded to the ear.
Great discussion and good insight.
B
URY914
May 4 2005, 07:32 PM
here are a few inner ear pictures I collected over the years...
URY914
May 4 2005, 07:33 PM
I'm saying I like this but here it is..
URY914
May 4 2005, 07:34 PM
other side
URY914
May 4 2005, 07:35 PM
last
J P Stein
May 4 2005, 07:42 PM
QUOTE (Brad Roberts @ May 4 2005, 05:20 PM) |
IF, I build another car for myself.. B |
Whadda ya mean "IF"?, damnit.
I'm depending on you building something that you can put all your ideas into practice, then I can blow you off at AX
Seroiusly, I would like to see something before I'm too old & f-ed up to get into my car.....5 years max, God willing.
After that, it'll be up to #1 son.
J P Stein
May 4 2005, 07:57 PM
Paul:
The black one don't look too bad, but I'd have to get a better look at the other sides. Nice stout plate, tho. Can't really tell what it ties into at the topo
The gray one.....I've seen the ear break off just below where that tube ties in.
I've seen some really nice looking (Strong, not pretty) done when guys raise the swing arm mounts.....got a pic here somewhere.....I think.
I'm gonna have to do something in this area. My new (IMPROVED!!) tiars are gonna raise hell with my chassis, me thinks.
(edit)
Humm....I really should take a close look at a pic before I post it
Porsche Doc
May 4 2005, 08:14 PM
Well that ought to stiff enought!
Added 20 lbs to the car too.
Hey Jeroen
The front and rear bar is a good idea. But you would want to cope the tubing into the ear so that it dosen't stick out pass the inside face more than the thickness of the material 1/8".
I also would still plate it like we do before adding the tubing.
Then you would have something workable.
URY914
May 4 2005, 08:15 PM
There is more steel there than in the roll bar!:o
Paul
J P Stein
May 4 2005, 08:40 PM
QUOTE (URY914 @ May 4 2005, 06:15 PM) |
Paul |
There's more steel there than in your whole freakin' car
