3/15/2017: Deposit taken. Sale Pending.
I've decided I have other needs for my limited shop space and that it's time to pass this project on to someone that will hopefully finish it in the way it deserves.
Asking $4000. Located in Southeast Michigan. Clean Michigan Title.
Pictures: https://drive.google.com/open?id=0B8SeihD2t...NkwtWTVlZ256QWM
Backup pics for people having trouble with the like above: https://detroit.craigslist.org/wyn/cto/6027516824.html
Pics are not up to date, and do not show surface rusting mentioned below.
Please message me if you are interested. General questions I can try to answer here.
1970 Porsche 914 - Unfinished Subaru conversion project
Body is solid, but has some surface rust from sitting in unfinished primer for too long.
You should plan on stripping to bare metal for a proper repaint.
Rust free hell hole. Car was originally a Denver car, followed by some time in the Pacific Northwest. Body was checked by Nate at ProVolks prior to purchase and given a “Thumbs Up”
1999 Subaru impreza 2.5 with 5 speed transaxle with 18,000 miles
Coldwater914.com Engine Cradle
Custom Axles
Transmission Converted to 2wd with coupler and Rear Plate
Transaxle Hangers
MR2 Shifter with Push-Pull Cables
Stripped Subaru Wiring Harness
Subaru gauges and steering column (not in car)
Radiator is in place with shroud, but not fully mounted.
Stock fuel tank with updated pump for conversion.
Fiberglass GT Front and Rear Bumpers
Interior: Dash is cracked, New carpet included. Bench style seat needs recovered or replaced.
All trim and lights included, previous owner removed during body work process.
Not included with the car, but available for additional purchase:
1970 911T Suspension (front and rear) for 5-Bolt Conversion
Set of (4) Boxster 16x7 wheels and tires
Subaru Legacy EZ30D Engine (would need harness and ECU)
2006 WRX Transmission, 3.70 final drive, ticking third gear.
The above items are NOT for sale until the car is gone and the car buyer has first option.
