Ross
Mar 7 2017, 10:13 AM
1972 914 1.7 Porsche
Hi Everyone,
Primarily when I put the car in reverse I hear a strange vibration/noise when I am letting the clutch out. I'm not 100% sure, but I may hear this sound a little when I am releasing the clutch in 1st gear. In both cases the noise stops when the clutch is released. I don't hear it in clutching to other gears.
I'm hearing that this could be a throw-out bearing issue. I know this isn't much info to go on, but have you all ever encountered this issue?
Thank you for any help, Ross
rgalla9146
Mar 7 2017, 10:26 AM
Put the car in neutral then apply and fully release light pressure to the pedal.
If there is a noise that comes and goes as you do this it is most probably a noisy TOB
Ross
Mar 8 2017, 12:10 PM
Thanks Rgalla,
I listened to a few youtube videos last night and it definitely sounds like a TOB problem. Now I just need to get the $ to fix it.
Take care, Ross
