QUOTE(Justinp71 @ Mar 8 2017, 07:04 PM)
Just make sure all of your hoses and fittings are rated for hi pressure before the pressure regulator if using the injection fuel pump. Which means no hose barbs and use fuel injection rubber tubing, don't want that hi pressure line to slip off or explode.
I run the CB performance 4.5 psi pump, it works great!
I agree about using FI hose between the pump and regulator, but I doubt if pressure is near as high as you suggest. I would think the pressure would only be say 4lbs, after that the fuel, thus pressure, is being bypassed and returned to the tank.
Pressure builds in a single line system because the floats are a plug, an on/off valve. In a two line system the pressure only builds to what the regulator is set at, then all the rest of the fuel is sent back to the tank. If you look at the PMO reg it obviously has a fuel return, it has 4 ports I assume in/out and one for each carb.
Also 914 stock FI (about 40lbs) uses barbs ends on the tubes with correct FI clamps, so I don't see the barbs that the OP has are an issue. On a FI 914 you only really need FI hose from the output of the pump to the regulator. Before the pump and after the regulator sees lots of flow, but it's just a low pressure system.
I highly doubt PMO would suggest using a FI pump if there was risk of it "exploding".
mmascari do you have the PMO pressure control unit instruction sheet? could you take a pic and post it?
I can't find it on the PMO site or doing a google search.
