oakdalecurtis
Mar 8 2017, 10:01 AM
76 2.0 FI stock except for Crane ignition. Car runs perfectly, all parts functioning, no vac leaks, idles at 6 to 700 fine. I was trying a possible fix for my engine "run on" after shutdown by adding a diode to the lead from the generator to the generator dash light. At the generator light in the dash, there is a blue wire to one side and on the other side is a short red/white stripe wire that goes immediately to the oil light. I installed the diode on the short red/white stripe wire between the generator light and the oil light. Did I stupidly put the diode on the wrong side of the generator light? Btw, I am taking the car in this AM for it's biannual smog check and I will have my mechanic check the timing before the smog check to rule that out as a possible cause of the "run on".
Olympic 914
Mar 8 2017, 07:08 PM
I was just wiring my dash yesterday and the diode in my wiring was in the Brown/White wire. Don't know about your year though, this is for a 73.
Dave_Darling
Mar 8 2017, 11:13 PM
That is a diode in the brake warning light circuit, not the charging system warning light circuit.
--DD
