finally getting around to reinstalling my clutch cable after a broken clevis at the pedal end
same cable & i didn't move the 2 lock nuts at the release lever end and replaced the clevis back to the same spot on the pedal end
so i figured i could just put it together pull the trunion block over to the realease lever and be good to go ... not so fast
trying it that way if i get the trunion in the realease lever i can't get the ferrule at the end of the cable sheath to go into the slot on the pulley bracket and if i leave the ferule in the slot i can't get the trunion to the release lever
in both cases i can move the release lever (by hand) about half to three quarters of an inch but just short of enough to get either the trunion or the ferule to seat where they're supposed to
so the initial seemingly obvious solution is i need to loosen the lock nuts at the trunion end enough to get the clearance then re-tighten to the previous
school me on how this works - can i just not move the release lever because i don't have enough strength in my hands to overcome the resistance of the diaphragm fingers but the mechanical advantage of the clutch lever and the strength of my leg does?
don't want to f anything up if i can help it TIA
cjl
