QUOTE(Gmanscott55 @ Mar 9 2017, 11:44 PM)
17" Factory Porsche 10 spoke wheel.
Click to view attachmentExact wheels I am running on my Subie conversion. Wheels themselves are BBS, fronts are 7.5x17 @ tad over 18 pounds, the rears are 9.5 at just over 21 pounds. Reason these look good is they are blacked out, so the eye does not grab onto the rim.
You can get the are to set correctly with 17s, BTW, it just takes some work. Raised spindles, and raised rear pickup points.
Current trend in old school hot rodding is rubber band wheels, with the rim built to look like white wall.
Click to view attachmentThose are 20s, look good, and proper for the car.
You could do the same thing with a 914, not white walls, but reduce the appearance of wheel, while still keeping the same overall diameter. The edge of the rim needs to be built out and blacked out to match the tire, and then it would look like a 15" Fuch in RSR finish, while it could be a 17, 18 etc....
