yarin
May 4 2005, 05:25 PM
Right now the car has a kerry hunter header into a straight pipe. Not exactly practical if you know what i mean.
This came with the car but i'm not exactly sure how to connect it all. Do I use exhaust clamps? Is this a spring type junction? Can anyone identify who made it?
Thanks
yarin
May 4 2005, 05:26 PM
more
SLITS
May 4 2005, 05:28 PM
It looks like there are tabs welded onto the various pipes. If the tabs mate, then it's bolts...if they don't mate then it's heavy springs.
You could also use exhaust clamps on the joints, but tightening them might distort the tubes.
yarin
May 4 2005, 05:31 PM
Hmm... i think you are right about the tabs that bolt together. It does look like the tabs line up and can bolt together. Thanks!
Aaron Cox
thats funky....
looks like a flowmaster muffler.... have no clue who amde it tho
yarin
May 4 2005, 05:35 PM
Yes the muffler is made by Flowmaster. I also need to come up with an exhaust pipe/tip to direct the exhaust out the back.
SLITS
May 4 2005, 05:36 PM
Some systems had tabs like that and used a heavy spring to hold them together so they could easily be disassembled at the track when the phrase "Chance favors the well-prepared" did
NOT work quite like it should.
Brad Roberts
May 4 2005, 07:26 PM
Do you have the stub tubes ?? I dont see them in the pics. It appears to be a early "Tangerine racing header"
B
yarin
May 4 2005, 08:55 PM
What are stub tubes?
This is all I have.
Joe Bob
May 4 2005, 09:01 PM
I think that model bolts to the heads w/o stubbies....
SLITS
May 4 2005, 09:04 PM
Hey Mikey.....those are flat flanges...there's gonna be a big gap if bolted up to a type four. There needs to be short piece between the flanges and the exhaust gasket to seal.....No?
Aaron Cox
May 4 2005, 09:06 PM
QUOTE (SLITS @ May 4 2005, 08:04 PM) |
Hey Mikey.....those are flat flanges...there's gonna be a big gap if bolted up to a type four. There needs to be short piece between the flanges and the exhaust gasket to seal.....No? |
ayuppers
Joe Bob
May 4 2005, 09:08 PM
Yeah...now that I look again...I have flat six in my head....think yer right...needs stubbies.
yarin
May 4 2005, 09:35 PM
Is this a generic "gasket" that I can buy?
Where can I buy this stubbie that everyone speaks of?
SLITS
May 4 2005, 09:42 PM
That I don't know.........you need a short piece of pipe to go between the flanges, into the recess of the exhaust port to compress the exhaust gasket. Secondly, the short "stub" pipe prolly has a flange on it to mate to the head pipe flange. I would assume a good muffler shop could fabricate them for you, but remember, the port is not round. If you have a set of stockers around, look and them and you'll get the idea.
Maybe Brad has some or Tangerine could fab them.
Brad Roberts
May 5 2005, 01:20 AM
I have none. You need the stub tubes. What you have wont bolt up to your heads. I would contact Chris Foley (Tangerine Racing) He is on the east coast and north of you.
Somebody somewhere has your stub tubes. I'm betting they are still attached to a set of heads sitting around somewhere.
B
yarin
May 5 2005, 06:04 AM
So I need these:
Thanks guys. i will contact the original owner and see if he has them.
ChrisFoley
May 5 2005, 06:51 AM
QUOTE (Brad Roberts @ May 4 2005, 09:26 PM) |
B |
That's not anything like my system, not even close, except for the fact that it's a tri-Y.
My stub pipes can probably be made to fit. I would need to know the primary tube diameter and have some details about the flanges so I can provide a set that bolts up easily.
ChrisFoley
May 5 2005, 07:02 AM
I took a guess as to which tube goes with which cylinder.
numbers one and two appear to cross under the flywheel.
You have the secondaries upside down. They appear to cross under the tranny. I can't tell which goes with which primaries but the 1 & 3 should pair up, also the 2 & 4 should go into one collector to a secondary.
ChrisFoley
May 5 2005, 07:07 AM
abcd
yarin
May 5 2005, 07:52 AM
Thanks Chris!
Yeah I see how it all connects. Once I get home I can take measurements and go from there.
larryp
May 5 2005, 09:33 AM
Chris, that was very, very impressive. You can play Legos with me anytime.
porschenut
May 5 2005, 10:34 AM
Gee, I guess you should have posted pictures to ask everyone what this was worth BEFORE you bought it!
yarin
May 5 2005, 12:41 PM
It came with the car as an extra. I want something on the car by next weekend, sounds like my best option is to find a supertrapp to bolt on or weld on to the kerry hunter.
Anyone got one?
yarin
May 8 2005, 09:01 PM
I've got a 2.5" supertrapp on the way. Here is a pic of the current setup:
I'll have a muffler shop cut the existing straight pipe and just weld on the supertrapp. Should be a painless procedure.
