Working on getting things set to install the engine in my GF's '69 Fastback. Replaced the TO bearing cross shaft with a stronger one due to the stage one Kennedy clutch on the engine.
The side to side alignment of the TO bearing is good, but one of the fork arms does not line up front to back with the other resulting in about .150-.250" of tilt on one side of the TO bearing. In comparison the original German cross shaft has no offset.
I would run the German one, but fear the factory forks and the welds holding them to the shaft are not up to the task of the higher pressures of the new clutch.
Should this offset be corrected, or am I just being over-critical? Not sure of what kind of clutch problems may develop from the misalignment of the TO bearing to the pressure plate.
It is an early style(pre '70) TO bearing setup without the guide collar over the input shaft.
Opinions/hints/tricks?
