Oil pump is a 30mm modified for full flow, comes with a limited edition Type I Killers RAT pump cover and Tool Steel intermediate plate - $80 for the set.
Single thrust Mahle Cam Bearings - $30 for the set.
Not pictured, I have a stock Oil Pressure Relief Piston with Spring - $5 or free if you buy the oil pump set :-)
Thanks,
Rob
