QUOTE(Andyrew @ Mar 17 2017, 07:14 AM)
QUOTE(Mowog4 @ Mar 15 2017, 10:21 PM)
QUOTE(Andyrew @ Mar 14 2017, 03:32 PM)
Ed,
Can you show us a picture of your cowl mounted heater core?
Here are some pics: The AC Evap/heater core mounts in the cowl, the blower motor mounts behind the dash (I am going to have to modify the glove box). The vents will be defroster, factory vents in the lower dash panel, and a couple of vents in the center console. I haven't run freon or hot water through the core yet, but the blower puts out plenty of air in the initial tests. It is the ugly black color because I coated the evap box with lizzard skin thermal coat.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachmentI like it! Which model kit did you use? I have something similar but its not separate like that, the blower and heater core are in one system. Did you custom make that?
I took an Old Air Products underdash AC/Heat kit and tried to make it work. I even went so far as to notch my Gas Tank and try to put it where the fresh air blower is. My biggest concern was how to pull the air from inside the car to the unit.
I ended up scrapping the unit, pulled the evaporator core out of it and built a 4" X 4"X 15" Aluminum box to house the evaporator. Then I mounted the blower motor on the inside firewall behind the glove box. The theory being it will pull air from the cabin, giving me recirculated air which should be more effecient.
In my quest for slightly better than mediocrity, the blower unit which came on the Old Air Unit was a Spal knock off which put out about 165CFM. I instead went with a genuine SPAL unit 008-A45-02 which put out closer to 300.
It blows into the evap box, which I insulated with Lizzard Skin Ceramic coating, and then routes to the defroster, center console, and side vents. I am expecting to control it from the factory blower, heat and defroster control. There will be a button in the center console which engages the compressor.
I have tried a bunch of combinations,I think this is going to work pretty well.
