QUOTE(John Jentz @ Mar 14 2017, 10:53 AM)
QUOTE(db9146 @ Mar 13 2017, 11:13 PM)
Has anyone found a source for the grounding stud on the passenger side engine compartment wall beside the battery? The PO sheared mine off like so
Click to view attachmentand I'm looking for something like this to replace it (Stanley Tucker Large Flange 8M stud).
Click to view attachmentI figure I could use a bolt but looking for a better solution if possible.
I just drilled it out and welded in a bolt and ground off the hex.
Hi John,
how are you?
did you ever find anything more with the GROUNDING STUD?
I am assuming that is the place everything is grounded to.
is that correct?
I need to check all my grounds.... make SURE they are all clean and contacting!
so I might as well start at the source......
Tomorrow, (long weekend) I will start there and follow everything back from there.
I would love a ground map? anybody every see or create a ground map?
914 luva
