I know, I know, I'm resurrecting an old post.
Yes, yes, drill for safety wire. My thoughts are that nobody should be on the track without safety wiring at a minimum all of your oil carrying nuts/bolts, including your oil filter. You can put a hose clamp on your oil filter and use the screw portion to hold the safety wire to a convenient place on the motor.
A dozen years racing motorcycles taught me to safety wire anything. Drill the holes 1/16" (very gently and very slowly so as to not break the bolt - a safety wire jig is cheap and good insurance to ensure you don't goof up), and use a good set of safety wire plyers. Grainger has a very nice set for about $100, though the $15 set on Amazon will work just as well. I forgot to mention, if you have a jig, it will work well in a drill press, don't force it.
If you are completely lazy, you can buy pre-drilled bolts to your spec at Fastenal, though it will likely be a special order, taking about a week to get there...
QUOTE(old914dog @ Mar 15 2017, 09:45 PM)
Drill for safety wire......it doesn't cost much!! And it can save embarrassment and $$$.
