QUOTE(6freak @ Mar 16 2017, 09:17 AM)
QUOTE(Mark Henry @ Mar 15 2017, 02:13 PM)
The RMS is under direct pressure from the #1 main bearing, the slightest scratch in the flywheel or crank mating surfaces will act like an oil galley.
One of the reasons not to use too much sealant on case halves is so you won't clog the RMS/rear main bearing oil drain notch. Clog that relief notch and the best seal in the world won't stop the oil coming out of the RMS.
you learn something new everyday
but that O ring has nothing to do with keeping the oil in the motor ...maybe I`m just missing it surprise
...ill have to dig into the book more
Remove your flywheel O-ring and report your findings...they should be easy to spot on your garage floor.
QUOTE(Montreal914 @ Mar 16 2017, 09:52 AM)
RMS seals around the neck of the flywheel, not on the crankshaft itself.
The O-ring inside the flywheel seals it to the crankshaft.
Exactly.
Just in case your argument is a /6 engine doesn't have a O-ring, it has a main bearing thrust surface that acts as a slinger, much like in a VW T1 crank on the pulley end. The oil gets slung off into the case before it gets to the RMS.
This is a common mistake that I've seen since I started wenching on these in the 80's, really I've known about this since watching my brother wrench on them in the 70's.
