oakdalecurtis
Mar 16 2017, 12:34 PM
76 2.0 California car. I have a couple of disconnected wires behind the gauges. All dash lights except the cat dash light are working. A pair of unknown wire leads is taped together with spade connectors on the ends. One of this pair of wires is a red with white stripe coming from the tach. I know this is 12+. The other lead taped together with it is blue with yellow stripe. I'm guessing that these two wires are the cat dash light leads. There is no light in the cat light socket, nor a sensor on the catalytic converter either. The catalytic converter has no wires coming from it, no apparent sensor on it, and only a half inch plug in the lower side of it. I cannot find a blue with yellow stripe wire on the wiring diagrams, but I'm guessing these are the wire leads for the cat light. Anyone know?
IronHillRestorations
Mar 16 2017, 12:53 PM
IIRC the CAT light is activated by a counter on the speedo cable. CAT cars have two speedo cables, one that goes to the counter box and from there to the gauge.
JeffBowlsby
Mar 16 2017, 01:17 PM
