aveale
May 5 2005, 07:14 AM
Okay,
This is not for the 914 purist but after I sent out another post, it got me a thinking..
Has anyone given more rigidity to the body by attaching the L and R Longs under the car?
Imagine the longs being reinforced with sheet metal (as mine has/will be) and then 2 cross members fore and aft of the passenger compartment UNDER THE CAR?
This will give L/R strength and make for some sure fire jacking points.
I would love peoples comments on this.........
T
John Kelly
May 5 2005, 07:27 AM
I've reinforced a few cars that had no roof structure, and have always thought it important to do bracing in the door opening if possible. This is the area that needs it most. Stiffening the door opening can be done more effectively with less added weight than anything down low. Reinforcing the longs side to side will help some I guess....just not much in the verticle plane. Cross bracing might more effective than bars straight across. A roll cage is your best bet for stiffness and safety. I'm not an engineer though....
John www.ghiaspecialties.com
neo914-6
May 5 2005, 08:07 AM
There are outer longitudinal reinforcement panels available, try a search. There are inner panel reinforcement also available in the resources section.
All alternatives to cage reinforcement...
URY914
May 5 2005, 08:27 AM
Left to Right is not really the problem with these cars.
It is back to front.
I be a engineer.
Paul
Jeroen
May 5 2005, 08:42 AM
I agree with Paul
No matter what you do, a "ladder frame" will not be very rigid
If you want to add some rigidity to your car, get an "Engman" kit (check the "parts&resources" forum and/or do a search)
Beyond that, you're looking at a full cage...
aveale
May 5 2005, 10:08 AM
cool,
i will check those spots out.
T
