djm914-6
May 5 2005, 11:03 AM
So, I've seen all these import guys painting their calipers in all different colors, but usually red. The look is starting to grow on me and I can't afford Big Reds or Carbon brakes. Has anyone done this?
Then, While looking for referance material, I came across a very cool night pic of a Le Mans car with glowing discs. That looked sweet!
So now I'm thinking... I've got a bottle of fluorescent orange paint that I doubt I'll ever use on a tee shirt (maybe Mike Rose's shirts will get a splash, but not a whole bottle)... I could just paint the entire brake disk Fluorescent Orange and get the look of a Le Mans car.
Do you think it will work? Betcha it'll look hella sweet. I wonder if the car will stop faster too?
freezing14
May 5 2005, 11:08 AM
the glowing disk idea is interesting but painting the rotor will for sure affect the braking,, and after half a second of braking, the paint will be gone,, on the other hand the caliper paint is great, I got the one specially made for that and it last a very long time with fading or tarnishing
mihai914
May 5 2005, 11:11 AM
Umm?
Any paint applied to the disc friction surface will be removed first time you will stop with the brakes, that is if you stop since the paint will probably affect the braking itself.
What you saw was really hot brakes (probably carbon) on a racing car that was designed to work with hot brakes.
If you want a better look, you can paint the calipers by masking the rubber boots and other areas that you do not want painted and shoot it with some caliper paint which is heat and chemical resistant.
double-a
May 5 2005, 11:20 AM
send em off to
goldline brakes for a durable red polymer coating. i recently had my fronts done:
~a
djm914-6
May 5 2005, 11:22 AM
What about neon then? Get some of that neon rope and pont it to the disc... how would you wire that?
Eric_Shea
May 5 2005, 11:27 AM
Ceramic caliper paint we did for James...
Eric_Shea
May 5 2005, 11:31 AM
QUOTE |
What about neon then? Get some of that neon rope and pont it to the disc... how would you wire that? |
Get some duct tape and tape it to the backside of the rotor... or for a more permenant mount use some small tube clips (available at Pegasus, Summit, JEGS etc...) and screw those into the rotor. Wire it directly to your headlights. Turn the headlights on and you're rock'n
djm914-6
May 5 2005, 01:23 PM
Oh thank goodness someone realized I was just kidding. I know I will be a future DAPO, but I'm not that much of a DA (that I know of).
Sorry for the missleading questions, like I implied, I'm just not in the mood to be at work today.
sixnotfour
May 5 2005, 01:30 PM
Hook it up to the brake light switch . Hit the brakes, Holy Hot Brake Look.
For added effect crosdrill rotors.
GoldLine does a good job with the polymer coating Red/Black, there gold paint rusts off in a month.
I want mine Gold Zinc Plated.
May 5 2005, 01:31 PM
who says you can't paint the rotors?
read all about it in an earlier thread here:
http://www.914world.com/bbs2/index.php?act=...5229&hl=blackie Andy
ArtechnikA
May 5 2005, 02:20 PM
QUOTE (SirAndy @ May 5 2005, 02:31 PM) |
who says you can't paint the rotors? |
Dave and i are fully up to speed on the "you can paint anything" concept :-)
Eric_Shea
May 5 2005, 02:38 PM
QUOTE |
I want mine Gold Zinc Plated. |
You rang?
Gint
May 5 2005, 04:49 PM
Just 'cause you can doesn't make it right.
