pugface
Mar 19 2017, 04:29 PM
Hi guys
Often time when I am trying to do some work on my car, I find instructions that skip certain things because 'everybody knows' some steps. Unfortunately, I don't know all the little tips and tricks.
I just pulled off my exhaust - the car came with a a Bursch glasspack exhaust that makes a terrible sound. My car also came with a bunch of spares, I thought I'd try the stock muffler that came in the pile. Although there were no gaskets when I removed the old muffler, I assume there should be?
Also, occaasioanly I see reference to copper nuts, copper paste, anit-seize - are there extra things I should be doing besides just using a new gasket and a bolt from Ace hardware?
I would like to be able to get this muffler off in a year or so, so any tips are appreciated!
Thanks
pf
Dion
Mar 19 2017, 05:15 PM
PF you'll need the appropriate gaskets for the type
of heat exchanger you have: 1.7,1.8,2.0?
There are no "copper" nuts per se. I think you are referring to the nuts that
go on the heat exchanger when mounting to case. They are sometimes copper color.
I just used the appropriate nut/bolt on muffler with a little anti-seize.
Torque appropriately.
Dion
Mar 19 2017, 05:23 PM
Gasket & "copper" nut
TheCabinetmaker
Mar 19 2017, 05:53 PM
If it were me, I'd bolt them up without the gaskets. Will it leak? Sure, but you will be able to hear the sound of the mufflers to decide which one you want. Then use the gaskets with regular old zinc plated nuts bolts and lock washers. When you remove the muffler a few years down the road grab a couple of long wrenches and tighten them till they break. Copper nuts are useless here.
I would also get in contact with the many 914 folks in the dfw area and the several members in boerne.
scallyk9
Mar 19 2017, 07:58 PM
In addition to Victor Reinz gaskets, my muffler installation kit came from AA with 6 bolts, 8 washers, and 6 "copper exhaust nut - 8mm self-locking". They don't look copper and I wouldn't be very concerned in that they are at this end of the heat exchanger. The self-locking nuts surprised me. I haven't installed the new muffler yet.
GeorgeRud
Mar 19 2017, 10:21 PM
I've always used the gaskets and regular bolts with anti seize, washers, lock washers, and nuts from the hardware store to attach the mufflers. I wouldn't recommend using the nylon locknuts as they might melt with heat from the exhaust. They've always worked and have unbolted when needed to swap out the muffler. I think you'll prefer the stock banana muffler to the rather noisy Bursch.
porschetub
Mar 19 2017, 10:45 PM
QUOTE(GeorgeRud @ Mar 20 2017, 05:21 PM)
great answer and
,just don't do them up crazy tight no need,if you have a leak put some exhaust sealant paste in there,you will be good.
rgalla9146
Mar 20 2017, 06:39 AM
QUOTE(The Cabinetmaker @ Mar 19 2017, 07:53 PM)
I agree, do a test without gaskets.
If you like it it's easy to slip the gaskets in later without lowering the muffler.
pugface
Mar 20 2017, 08:37 PM
Thanks guys!
I did the 'test bolt-on' of the used original muffler today. Took it out to get the mail, and it did sound better to my ears. Quieter too, although that is relative
Gaskets are on order, and I hope to have it installed for real this weekend
pf
