I have restarted working on this project again this week. It was delayed since I had finish so many home projects that I put on hold to finish my 914-6 GT clone last year.
http://www.914world.com/bbs2/index.php?sho...9197&st=120The object of this conversion is to convert a 914-4 steering column to accept a 911 ignition switch on the left side while looking as factory correct as possible. This cuts the conversion cost considerable and makes the wiring modification much easier. When completed it will have a functional steering lock and use the heavier duty 911 ignition switch. Oh, forgot to mention the cool factor too!
After some research and some very helpful dimensional information from SixerJ it was time to proceed with modifying my steering column. The project is going to require several steps to accomplish:
1. Steering housing-cut off existing ignition switch protrusion then machine housing and fabricate filler plate.
2. Steering housing tube-machine window to accept 911 ignition switch and fabricate horseshoe bracket to clamp 911 ignition switch
3. Steering shaft-cut off ignition switch locking tabs and move them three inches down the shaft
4. Dashboard-cut out left switch hole and weld in new 911 ignition switch mounting
5. Modify 914-4 ignition switch wiring to accept 911 ignition switch.
The first step was to cut off the ignition switch protrusion from the side of the housing. This was rather easy to do with a cutoff wheel.
Click to view attachmentThen I set the housing up in a mill and machined about .08 deep ledge that goes up to where the arrows are pointing.
Click to view attachmentThe machined ledge supports the slightly curved piece of stainless steel the fills in the gap where the ignition switch used to be.
Click to view attachmentI welded a tab to the stainless and used the existing holes from the old ignition switch housing to mount the filler plate. I still need to paint or powder coat the housing black.
Click to view attachmentThe next step is to machine window to accept 911 ignition switch and fabricate a horseshoe bracket to clamp the 911 ignition switch.
Click to view attachmentClick to view attachmentBelow shows a test fit up of the ignition switch.
Click to view attachmentI still have a lot more work to go but I actually think this is going to work.
Jeff B
