If nobody has one to sell, then you might ask to borrow one as a pattern to get it fabbed local to you, or local to the "lender" - or maybe dlee will share his drawings or pattern to make one. Just a plan B thought.
PS - I just noticed that you're down in OZ - so probably the latter 2 of the above plan B's - having it fabbed in the States off of another or dlee's pattern then shipped down under to you will work - unless there happens to be someone in OZ with one.
PSS - That also looks like it's made to fit the larger York R32 type compressors &/or aftermarket early ones, but you can get the complete modern R134 AC system with the more efficient rotary compressor from Auto Atlanta which will only "rob" 1-3 HP vs. 7-10 HP on the old type Yorks, & IIRC they also have the mount for the system - either in the kit or as an added part for those updating their original Porsche+Audi VPC or DPD AC systems. Yes they're expensive for a complete system, but their new, & won't run $100+ USD per can of R32 & ever rising - & which will eventually run out. A coupla-three of R32 recharges will easily run $1000+ USD over time! IMHO go for the dual condenser kit for Brisbane.
http://www.autoatlanta.com/porsche-parts/a...CLIMATE-CONTROLCheers Mate!
Tom
