Full Version: FS Front Sway Bar, 19mm New hardware, used bar $350
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
bdstone914
The sway bar levers and installation hardware are new from about the 80's. Has original yellow faded instructions from H & H. Had to make one top block for a lever, then had them powder coated. Includes hardware to install triangle mounts into the body. Requires cutting and metal work skills. That means if you do not know what you are doing don't try and screw it up.
Bar is a 19mm and in good used shape. Paint worn on the ends.
The longer levers give the 19mm bar a setting that is closer to the original 15mm bar, if used on the farthest out setting.
New sway bar drop link bushings will be bought and included.
$350 plus shipping which runs about $25 in the U.S.
Will ship worldwide at cost.
Bruce
bdstone914
bump for picture added
Invision Power Board © 2001-2024 Invision Power Services, Inc.
