So the brake caliper fiasco continues. It turns out that the Postal Service is responsible for the missing caliper half. The plater returned all my hardware in the same boxes I sent them. At first I was annoyed because they were beat to hell and not fit for shipping heavy contents. It turned out to be a lucky thing though as on the side of the crushed boxes, almost hidden under gobs of tape were two stickers apologizing for the damage that occurred at the Milwaukee sorting facility. I had insured the boxes and have filed a claim so we'll see what happens.
In the mean time, I pulled out my like new caliper pistons and rebuilt the first front caliper. It really looked nice with new seals and piston retainers. It was also pretty easy to correct the color on the bolts. A hot soak in TSP degreaser strips yellow chromate right off without harming the zinc. Then a very quick (about 2 seconds) dip in dilute hydrochloric acid to reactivate the zinc to accept chromate and a 20 second dip in black chromate followed by drying overnight. Not too bad.
Click to view attachmentNow just a matter of slipping those bolts in and torquing the halves together. First round of torque is a light 7 lbs. just as the bolts started to snug, they popped loose
If you read my other thread on this, you already know that all my calipers are now FUBAR. Apparently too much time in the acid bath prior to plating eroded the threaded holes. Well
! That sucks. But if you read that thread, you also know that several saviors rushed to my rescue.
@sixnotfour ,
@mepstein ,
@mb911 , and
@Eric_Shea , I can't thank you enough.
Thanks to them, I'll have a good set of cores to have plated and get back in business here. This time I'll do what I should have done in the first place... let PMB handle the plating.
Okay, moving on. I have a lot of bling to put back where it belongs.
Ignore the engine mounting bar, that still needs a refresh but I did manage to finally get the bolt that was rusted in out with a lot of MAPP gas and a BFH. Surprisingly, only quiet swearing under my breath was required which for me, is pretty much like a kitten purring.
Click to view attachment These nest pics are @defiantly 's fault. I was perfectly happy to hide tarnished clips and valves under rust encapsulator until he showed off his handiwork. After that, I had no choice but to do it right.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentThen I kind of ignored
@914_7T3 'advice and went ahead and installed the air diverters. I may regret this when I install the air box after the exterior is painted, but it looks like they won't interfere and I think have the cables already routed before the box goes in will help. It looks nice now anyway.
Click to view attachment Click to view attachmentClick to view attachment
