Operation Alternate Reality Complete.... i hope... Got the new slip rings and brushes to put on the unbent rotor. Removing the slip rings is easy, just a small puller works. I just pulled it up part way and then desoldered the lower rotor winding wire before pulling it the rest of the way.
Click to view attachment Then I hit a snag when the fiber insulation on the slip ring connecting wires turned to dust. This sleeving is much smaller diameter than the diode sleeving so my salvage stash did me no good. I went all over town on Friday trying to find some high temp fiberglass insulation sleeve. No luck. I had resigned myself to another delay as I waited for another ebay order but a Saturday morning scavenger hunt through my halogen scrap pile again and found exactly what I needed. Rather than try to strip the wires completely and risk doing more damage, I just stripped them back to good insulating and wrapped the joint with some polyimide tape I had on hand. The tape is just to make sure the wires don't ground to the armature before being encapsulated in epoxy.
Click to view attachment After the new slip ring was replaced and wires soldered on, I needed to secure and encapsulate the wires to the top of the rotor. The factory used insulating varnish which you can buy for about $8 shipped on ebay, but I had this epoxy potting compound left over from the relay board so I decided to use it.
It is rated for a constant service temp up to 284F and intermittent temps up to 347F. If my alternator gets that hot, I have bigger problems than failed glue. The only downside of the potting compound is that it is runny. Something a little more viscous would be better but it just took a little patience to build up a thick enough coat.
Click to view attachment After assembly, the rotor tested 4.3 ohms resistance between slip rings. Right on spec.
Now time for the brushes. Nothing exciting to report there. Just desolder the old ones and solder in the new. Here's a pic with one old and one new brush installed to show the wear. Still plenty of life left in the old brushes if I hadn't broken the wire on one.
Click to view attachment Now to figure out how to get the rotor in without trashing those new brushes. If the brushes are worn down enough, you can just leave the brush holder loose and push the brushes back out of the way while the rotor slides in. That's not an option with long new brushes and "Pull up carbons before installation and arrest" still wasn't helping me understand how to proceed for some reason. After fiddle farting around with bad ideas, I finally figured out you can push the brushes in and then grab the braided wires connecting them with a thin needle nose pliers through the plug connector.
This are the wires to grab.
Click to view attachmentPinch them with needle nose while pushing the brushes all the way into the holder.
Click to view attachment Now you can easily slide the rotor into the housing without crunching the brushes.
At this point, I had run through all the tests in the factory manual that can be done with a multimeter and the alternator outside the car. All 9 diodes tested good, as did the rotor and stator. It would be nice to test the output before bolting it in but I couldn't find any information about how to do this with an external regulator. I called my FLAPS who said they could do it but didn't sound that confident. I was skeptical but hauled the assembled alternator into the shop. Sure enough, as soon as it went on the bench, the diagnostics said the alternator could only be tested in the car. Oh well. I decided to just bolt it in. In theory, anything that could be bad has been replaced and/or tested good.
I bought a new gasket for the rear cover - some assembly required.
Click to view attachmentThen I connected the harness I made, put the cover on, and bolted it in place. So here she is back home after 35 years.
Click to view attachment Click to view attachment I won't lie. This project was not easy, but was it worth it? Absolutely. The best price I've seen for reman Bosch alternators is $167 at NAPA and most suppliers are listing over $200. The grand total that I have in mine to refurbish is $25. For a guy with more time than cash, that's a good deal. Plus, I now know a lot more about how alternators work.
