Thanks for the compliments everyone. It really means a lot. The wife approved too. After seeing the paint, she started talking about how fun these cars are to drive. Quite a departure from the ridicule or quiet suffering of this project.
I was asked to share some details on the paint correction (a.k.a. fiasco recovery). I've also had a couple people mention they follow this thread for guidance on their own builds. Seems crazy but maybe most valuable as a guide of what not to do. So here are just a few details on the correction and then a couple other lessons learned the hard way.
There's not that much to say about the correction. I simply wet sanded all the pools, runs, and slobber off using a durablock. I started with 800 grit which seemed like a good grit for bringing the surface flat again. If I were going to just sand and then cut and buff, I would have stopped when there were just shallow low spots left and switched to 1500 grit and progress to 3000 before buffing. In reality, I probably could have just sanded and buffed my way out of my mess, but there were other problems with the paint to correct.
Once I decided I would respray base on the hood and cowl, I switched to 600 grit to speed up the job of flattening the surface. At that point, I wasn't worried about going through the clear as long as I didn't sand through the primer. I did sand through the clear in a couple places but have to say it took a LOT of sanding to get there. Pretty much had to do it on purpose. 600 grit was fine enough for respraying base so I left it at that. On the fender, I stuck with 800 grit since I was only going to respray clear there. Again, that was fine enough so I didn't do anything more than flatten out the runs and sags from the spill, and scuff the whole surface of the panel.
I only did one thing special during the respray. I masked off the whole car, including the left fender that would get clear. I sprayed base and one coat of clear on the hood and cowl (including windshield frame). Oh yeah, I also taped the f-ing lid on the sprayer cup this time
After the coat of clear, I pulled the masking off the fender and shot two more coats of clear on all the panels. I just guessed that I had left about 1 full coat of clear on most of the fender, so shooting one less coat there would give me about 3 full wet coats on everything. PPG says to spray 2 coats but since I planned to cut and buff, I sprayed an extra for sanding.
That's pretty much it on the correction. Just a lot of work but nothing fancy.
A couple other tips:
Beware of this masking plastic. I loved it for fast masking and it worked great for primer, but sealer and base coat did not stick to it at all. That blew paint flakes all over the shop and a lot of them wound up in the paint. I was able to deal with it mostly but there are a few flecks here and there that aren't too noticeable. If I do this again, this shit will be banned for the final spray.
And another 3M product that pissed me off. I f-ing hate this foam tape. I think I just bought the wrong stuff for what I was doing but it was nothing but an expensive PITA. The adhesive is very weak so I would spend hours masking and sealing all my door and deck lid gaps only to find the tape had fallen off an hour later. I even had a piece lying on a horizontal surface that unglued itself overnight and rolled away. I have nothing good to say about this crap. Like I said, I probably just bought the wrong stuff. There are lots of different foam tapes available.
Last tip specific to spraying metallic. It is imperative to have the right vibrations in the air for the flakes to lay properly. You need to play period correct tunes and play them loud. For my 73, I went with tunes from the late 60s through 73 which includes some of the best damn music ever created. And no Bee Gees dammit. Don't be a dick. These aren't disco cars. Disco sucks. A few sentimental pop hits are okay between coats, but you want good classic rock buzzing those flakes into place. Here's a small sample of what was in the air when I sprayed my car.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment
