So what's been happening with the car? Sanding, sanding, and more sanding. I've been working long hours for my job but have spent all my free time for over a week cutting the paint. It was more work than it should have been thanks to me not knowing what I was doing. The only PPG clear I could buy at my paint shop is intended for collision repair. PPG recommends it for 1-3 panel repairs and from what I saw, that was about spot on. It flashed so fast that I had a hard time getting around the whole car without having overspray pile on the flashed surface. It wouldn't be a problem for a good painter, but I didn't have one of those available. Then there was the big spill fiasco which complicated things. The upshot is that I had a lot more sanding to do than I should have. It was amazing how much easier the panels I had really sprayed well were to work flat. Probably only 1/4 of the time as required for shitty panels.
Anyway, after many, many hours of work, I finally had everything sanded to 3000 grit by mid-morning yesterday. And yes, I did wind up resanding the hood to get those scratches out. Here it is after sanding and with just the corner after the first cut of compound.
Click to view attachment I got the first cut done and half way through the second cut yesterday before having to quit early. I'm really happy with this Chemical Guys polishing kit. Everything needed to polish a whole car for $150 can't be beat. If I were going to be doing a lot of polishing, I'd want a better machine, but it is high quality and perfect for occasional use on the cheap.
Today I finished polishing (4 grits). I'm pretty happy with the results. I'm going to rate this paint job a "two footer." It looks pretty darn good up to two feet away. Closer and it isn't hard to pick out flecks of shit here and there. You have to look for them though. Put another way, the average Joe drooling over the car at the gas pump will think it is amazing. Anyone who actually knows what a good paint job looks like will quickly say, "Good for you trying to paint your own car little buddy."
So here are some typically bad picks. If I get a chance on a sunny day, I'll roll it outside for better picks.
Click to view attachment Click to view attachment Click to view attachment And the other side:
Click to view attachmentWhoa! That looks like shit. What's the deal?
If you've been following along with this project, you know I can't go long without f'ing something up, but give me credit for being consistent. Yes, of course I sanded right through the clear and into the primer. In two places actually. Quite easily too.
Click to view attachment I obviously got the clear way too thin in this area. That area was a bitch to see and reach when I was painting and it also happens to be just downstream of my painting progression from where the spill happened. I probably was so frazzled at that point that I failed to get the final coat on at all. As unhappy as this makes me, I would much rather discover it now than in a year when the paint started to fail. Of course that's not all. This next one is truly a dumbass move. I was working on the roll bar when the wife walked in to chat. So we are talking and I keep sanding but not paying attention like I should. Bad move. Next thing I know, I have a little spot of primer peeking out in the corner.
Click to view attachment What a dipshit!
So here's the plan. The sand-thru on the front fender is low and inconspicuous enough that I'm going to try to just airbrush a little base in to blend the goof and then reclear the whole panel. Even if they blend isn't 100% perfect, it will be hard to notice. I would try the same on the door but there is some trash right above the door handle which is a particularly annoying place to have a blemish. I'll probably just respray the door with base and reclear. On the roll bar, I'm going to try the same as on the fender. I experimented a bit dabbing base into the sand-thru with a touch up brush. The results were promising enough that I think I can air brush in base to make the blemish disappear. Of course the whole top of the roll bar will be shot with clear. If I can't make and invisible patch, I'll reshoot that with base too. I'm hoping to do that next weekend so we'll see how it goes.
I had enough time today to do a few fun things after the polishing was done. I know the factory just sloppy brushed flat black in this area but I could quite bring myself to do it. Just a single coat of trim black here though.
Click to view attachment Trying my best to keep up with
@mb911 but it isn't easy. Ending this with a symbolic step... or in this case, maybe it is emblematic?
