The Blue Dot As usual I've been juggling several projects on the car with plenty of progress but few at an interesting stage to share - except one. It was time to add some tunes to this tub.
I spent a LOT of time trying to figure out a head unit that suited me. For months I had a search alert for vintage Blaupunkt and Becker radios to see if I could snag a bargain. No luck. As everyone knows, those radios have become quite spendy and in the end, I simply couldn't justify if for 1970s electronics and, at best, a clunky interface for incorporating bluetooth and digital streaming capabilities. Next up was looking at the retro style modern radios. The best seem to be from Woody's Custom Radio. Still, they are not cheap and specifics on what you are getting are kind of vague. So what about a modern head unit? Well - they are almost all ugly as shit. The look like the spawn of hip hop and disco on crack. Things were looking bleak.
What about the Blue Dot? I'm not sure how many know that Blaupunkt really no longer exists. It is now owned by an investment conglomerate that simply licenses use of the name and logo. Still, I was curious so checked out their offerings. Nope, I found some of the most hideous looking POS radios yet. Then somehow I discovered the "International" region website for Blaupunkt and finally found head units with much more subdued styling and a bonus of the blue dot logo that looks at home in our cars. They are still made in China radios but I found one that had the features I wanted and styling that didn't make me want to hurl. It isn't going to pass as period correct by any stretch, but it looked like it would fit into the interior without being a glaring eyesore.
I'm not crazy about the blue ring lights on the knobs when the power it on, but otherwise like the style. I didn't, however, like the stock mounting which leaves the nose sticking too far out of the dash with a bulbous plastic bezel.
Click to view attachment Something had to be done about that so I fabricated a pair of custom brackets that nestle the unit deeper into the dash. I don't have good tools for cutting clean slots in sheet metal so they look pretty amateur, but nobody will see that when installed.
Click to view attachment I planned to screw the brackets to the chassis but they snap so tightly onto some lugs I decided they weren't needed.
Click to view attachment Mission accomplished. With the unit mounted just a few mm proud of the dash face, it blends in much better.
Click to view attachment Next, I built a wire harness to hook it up. I bundled the unused wires near the radio plug outside the main harness so I can access them later if needed. The power antenna wire in that bundle will be tapped for an amplifier turn on wire but I'll wait until I'm certain where the amp will be mounted before adding that.
Click to view attachmentStaying true to the factory radio harnesses, I used AMP dual gender spade connectors so I can plug this harness into appropriate switch terminals on the dash, and plug the original switch wires into the male piggy back spades. Works pretty slick.
Click to view attachmentFinally, I fabricated a custom dash plate using my original as a template. I still had a scrap of the original trunk lid left which is the unobtainable exact gauge as the dash plates. I sure was jealous of
@tygaboy 's plasma table while cutting this. I had to do it the hard way with snips, a jig saw, and files. Here's the original plate in the middle, with new plate below and all that remains of the original trunk lid above.
Click to view attachment Covered in basket weave and installed, I don't think it is too bad. I have one more detail I'll probably add and will update on that later.
