I've been working furiously to get my tub ready for primer so I can take advantage of what will likely be the best last good weather forecast for later this week. I've spent a lot of time metal bumbing to get fenders as straight as I can, and dialing in door gaps.
Metal bumping takes a LOT of time. Most of it has gone pretty well but the passenger side quarter has been a challenge. Before I owned the car, that panel had been hit, dirlled and pulled, gouged, and slathered with a thick coat of Bondo. Then I cut it and rewelded. In other words, it was a mess. After hours with hammer and dolly and the shrinking disc, I got it close, but not perfect. Low spots are quite shallow (less than 1mm) and the panel is tight with no oil canning. I'd love to keep working those low spots but I'm I'm im a race against Mother Nature so don't feel I have the luxury of spending several more hours. I may come back to it if time allows.
Click to view attachmentLack of skill is definitely a limitation, but there is another that prevents this panel being perfect. There is mild pitting on the backside of the panel. In hindsight, I could have tried filling the pits with the Fiber Tech filler and smoothing before metal bumping, but I didn't so those little pits telegraphed through so will need filler on both sides to get smooth.
Click to view attachmentI started with the passenger side. I F'd up the gaps stupidly trying to sharpen the corners along the lock post with a hammer. I cut a piece of flat bar to let be reach inside the quarter panel and massage the metal back where it belonged.
Click to view attachment That worked pretty well. The gap averaged about 4mm which is good, but wast narrower at the bottom and a bit wider at the top. I've obsessed over any pics posted showing door gaps over the last year and a half and paid particulary attention to survivor and unrestored cars. I've noticed that gaps narrowing at the bottom is pretty typical so I decided to leave the bottom alone, but I wanted a max of 4mm at the top so started by added a bit of metal along the lock post edge.
Click to view attachment Next I sprayed the edge with gray primer and set my compass to 4mm to strike a line to grind to.
Click to view attachment Not looking too bad after grinding.
Click to view attachment Next was applying a bit of the Fiber Tech filler to smooth the edge and refine things a bit more. I'm pretty happy with the result.
Click to view attachmentThe gap a above the door lock is still a tad wide (~4.5mm - 5mm). I might revisit that later but this also seems fairly common so it isn't bothering me too much. My goal here is to have a car that looks factory fresh - no more, and no less perfect than the factory produced (but with better rust protection
I have a couple minor dings to tap out on the extreme rear quarter and after that, I think this side is ready for final prep for primer. This is only the DTM reinforced Fiber Tech filler over welded patch, but so far, doesn't seem like an embarrassing amount of filler. There will be more conventional filler applied over the epoxy primer but I'm confident that I'll have reduced the amount of filler that was on this car by about 95%.
Click to view attachmentThe only thing I did on the front gap was adjust the patch at the bottom of the fender for perfect alignment with the door. Again, it narrows toward the bottom but that seems typical. The gap at the top is a tad wide but the door is hung about 1mm too low so that will tighten up with final (and proper) door adjustment.
Click to view attachment Okay, lunch break is overy, I'd best get back at it!
