Made some progress on the rear axle. This morning I got the rear sway bar painted. It's just finger tight mounted for storage until I get a consensus on what to grease the rubber bushings with since "glycerine paste" doesn't seem to exist. I thought I had a set of drop link bushings but apparently not. I'll have to order some.
After work, I put the trailing arms together. Installed new SS pivot rods from 914Rubber and their hard bushings. Nothing exciting about the install so I didn't take any pics. I'm hopeful they'll offer OEM style rubber bushing soon so I can swap these out. They fit well though. After that, I moved to the hub. The HF Front Wheel Bearing kit makes installing the bearings and hubs easy work.
Sorry I didn't take a pic of the bearing going in, but here's the setup. Pretty simple. Choose the correct sized discs to pull the bearing in without pressing on the fragile parts, and suck it in with an impact driver. With frozen bearings and a thin smear of grease in the polished hub, it takes less than a minute.
Bearing is in nice and flush.
I put a very thin smear of anti-seize compound on the bare metal flange before bolting on the replated cover and torquing to 18 ft-lbs.
The procedure for installing the hub is a repeat of the bearing except with different sized discs. Most important is to choose a disc that fits inside the bearing housing and rests on the bearing itself. That way you don't put pressure on the bearings as the hub pulls in. I stopped with the hub a millimeter or two of being seated so the final seating will be done when I torque the stub axle down. I'm still waiting to hear from Porsche about the CV joints so I can't install stub axles or make the car a roller until I have that taken care of. Here's the hub in place.
Two rebuilt trailing arms. Took less than an hour including dicking around just admiring them. I guess I should plate up some hardware so I can bolt all this on the car.
