Looking at my "4" yesterday while at the shop a previous repair was done to the tube and firewall area.. Isn't the tube supposed to protrude out of the back of the firewall like the throttle cable does ? So is my case the clutch cable is loose on to the firewall..
My question is how much tube should be extending out of the firewall ? On the clutch adjustment there are about 1.5"+ of spacer washers there..To repair it can a smaller diameter tube inserted in the existing tube a welded on,as only the cable goes thru that area? I still have to Ck the tube connection points it the tunnel..
Thanks for all the help..
Alan/ 914Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=
598493]Click to view attachmentClick to view attachment
