QUOTE(rgalla9146 @ Apr 5 2017, 08:38 PM)
QUOTE(Mark Henry @ Apr 5 2017, 08:33 PM)
QUOTE(rgalla9146 @ Apr 5 2017, 08:01 PM)
Many thanks to Mark and Mark
Great info.
I'm still hopeful that a combination might be found.
I think I have the four 108mm CVs. the stubs and hubs.
The width of the gearbox (flange to flange) has to be measured and compared to
a 914. Same goes for half shafts.
I have my engine trans out right now so I'll measure the width of the 914-901 flange faces for you. If they turn out to be the same you should be able to use the same sway-a-way axles.
Count the number of splines on the ends of your axles.
Hey Mark
I have both transmissions with flanges here.
I'll get to see the 911 shafts and CVs tomorrow.
Luckily access is pretty good.
Well you guys knew right from the start.
108mm CVs on both ends.
'71 to '74 911 stub axles and wheel flanges or 914 6 wheel flanges.
Trans width flange-to -flange is the same.
So..... Sway a Way ( 930 ? ) shafts complete the set up.
Can somebody confirm length ? Same as 914 ? Same as 930 ?
I turns out I have the parts and didn't know it !
Check out how tight the stub axle is inside a 914 trailing arm.
Thanks again guys.
