RangerRhett
May 7 2005, 10:07 AM
All,
Just got the car off jackstands and fired 'er up. Now my e-brake light is flashing even when the brake is dis-engaged.
Where is the relay/switch for that light? Anyone have any ideas? I have been poking around but not found anything.
mihai914
May 7 2005, 10:09 AM
The switch is on the master cylinder, remove the boot to the wire and you will see it, small plastic pin, push in and have fun.
Mihai
May 7 2005, 10:18 AM
QUOTE (mihai914 @ May 7 2005, 08:09 AM) |
The switch is on the master cylinder, remove the boot to the wire and you will see it, small plastic pin, push in and have fun. |
master cylinder reset switch ...
Andy
RangerRhett
May 7 2005, 10:29 AM
Sweet....
I was in there 'screwing around' yesterday...I may have bumped it!!!
Damn...back in the air she goes...!!!!!
mihai914
May 7 2005, 10:32 AM
You probably unhooked the wire by inadvertance.
RangerRhett
May 7 2005, 11:36 AM
Probably...
McMark
May 7 2005, 12:21 PM
Why is it that every time this comes up I have to be the one that says that not all master cylinder switches have the reset button.
I believe it's only the 1 wire ones that have the reset. The two wire ones do not.
john rogers
May 7 2005, 02:54 PM
True, there are some with NO reset switch. My race car is like that and I finally disconnected the wiring for the flashing light circuit since I don't really need a light to tell me the brakes are not working......
john rogers
pete-stevers
May 7 2005, 03:10 PM
thanks mine was flashing too
.....I was to lazy to ask
....glad you asked for me....
mihai914
May 7 2005, 04:19 PM
So what has to be done with the early type two wire switch?
redshift
May 7 2005, 04:32 PM
If it's flashing twice, that's an error code for the headlight washers.
M
mihai914
May 7 2005, 04:35 PM
QUOTE (redshift @ May 7 2005, 05:32 PM) |
M |
Is it two long or short flashes because the later one is for the airbags?
Pugbug
May 7 2005, 08:42 PM
Is the e-brake handle going all the way down and making contact with the switch under it? If so maybe that switch is hooped.
