QUOTE(audio_file @ Apr 8 2017, 07:37 PM)
I found it frighteningly easy to plug the wires into the injectors backwards, double check that... if you replaced the fuel filter up under the fuel tank, check to make sure you didn't pinch a fuel line between the tank and the car body if/when you moved the tank.
Thanks for the help. It was a pinched fuel line.
