djsinister702
May 7 2005, 03:27 PM
ok,
just bought a set of fog lights...plug it into the existing wire in the front trunk...no lights??????
anyone know how it is turn on???
1975 914 1.8L
also, seem like the horn dont work...i found these wire in the front truck...what does it plug into?
Allan
May 7 2005, 03:45 PM
My car has a switch by the headlight control.
grasshopper
May 7 2005, 04:01 PM
those wires are for the fog lights....
markb
May 7 2005, 04:03 PM
And fog lights only work with the low beams.
djsinister702
May 7 2005, 04:08 PM
there are no switch to turn it on...
that does mean i would have to put one on??? and where are the wire???under the dashboard?
Demick
May 7 2005, 04:36 PM
You'll have to buy a switch and put it in. The wires are there behind the dash to hook up to the switch. You also may need to add a relay (standard round relay) to the top side of the fuse panel (there will be a socket for it). But the relay may already be there.
Demick
djsinister702
May 7 2005, 04:41 PM
ok.
just order a switch...will hook it up soon as i get it..
thank you all for the info...
