rjames
Apr 10 2017, 04:39 PM
Clock:
I think I fried my center console clock when both the + and - wires made contact on the negative terminal of the clock. I took it apart hoping to find the built-in 'fuse' had blown, but it didn't. It's an early model. Has anyone rebuilt/repaired one successfully, or have a recommendation of someone that does repairs? Or would I better off just placing a WTB ad in the classifieds?
Voltage gauge:
Center console voltage gauge always reads 0, although the needle tries to move to the left of 0 when I turn the lights on. It's almost as if it needs to be calibrated. Is there an internal calibration mechanism? I didn't want to take a chance in trying to pry the metal bezel off if there wasn't. Alternatively, does anyone repair these?
halmil
Apr 10 2017, 05:31 PM
I used Palo Alto Speedometer to convert my clock to a quartz movement. Works great. They are very well-known for instrument repairs
914Sixer
Apr 10 2017, 05:32 PM
No adjustments on voltage gauge that I know of. Clock repairs are in the $150 range. Probably want to post ad.
9fourteen14
May 30 2017, 08:53 PM
what goes wrong with the clocks?
mine is NOT working either but......
so what happens to them?
how can I get mine working?
thanx
Coondog
May 30 2017, 09:13 PM
GregAmy
May 31 2017, 07:33 AM
You sure you didn't just pop the car's fuse? Connecting both + and - to the negative terminal would just send power to ground through the - wire, not through the clock, and pop the car's fuse.
Check The Simple Stuff First.
Dave_Darling
May 31 2017, 04:32 PM
If the voltmeter is trying to go the other direction when the car is on, you may have the power and ground wires swapped.
--DD
