Curtis,
I agree with Mark Henry & the Newbie (WTTC BTW) - run to the taillight, & IIRC you can pass it through where the main harness goes into the rear trunk on the driver's side, & where it passes into the cabin, behind the backpad & roolbar pads to the light.
If you got that GoWesty one which I suggested, then there may be enough of a lead that comes with it to reach, but trial it from the outside of the car first & add a coupla-three feet extra for the maneuvering around the body. If too short, then get some matching wire gauge/colors, in-line connectors with shrink-wrap to extend them hopefully within the trunk.
If it's another 3rd light, then I don't know how much wire they supply, but process is the same.
Good Luck!
Tom
