QUOTE(914itis @ Apr 16 2017, 08:16 PM)
What's the secret with that ?
Last year at Hershey , one came out that I replaced. I replaced them again with brand new seal from pelican, leak again.
no scratched on the surface and surface is clean. Seals are tight. Do you push them Althea way against the bearing or flush with the outside perimeter?
Paul, I am pretty sure those seals are supposed to sit slightly below flush with the outside, but there is some tolerance. There is a lip on the inside, and I think ideally they sit against those. But you don't want them so deep that they sit against the bearing. I would just make sure the mating surfaces, including the output flange surfaces, are as clean as possible.
