I need the double banjo fitting from an early pressure regulator . Number 27 on the pet catalog. I also need the banjo bolt for that fitting.
I also need the 90 degree brass fitting (number 15) that goes from the brake line through the tunnel to the line that connects to the bottom of the early pressure regulator.
Thanks,
Buck
