QUOTE(yellow75 @ Apr 20 2017, 06:40 AM)
same as a VW? Is trans removal a one man job?
Easier than a VW,top starter bolt is a bitch to get at till you drop the trans down a bit before blocking the motor up.
Get on to it soon before the leak ruins your clutch disk,make sure you replace the throw out lever cup bush and the sliders for your bearing.
I made a wooden base for my jack and strapped the trans to it....then its a one man operation.
