QUOTE(aturboman @ Apr 20 2017, 09:10 AM)
SEM Trim Black is an excellent match and top quality paint. Typically you'll need to get it from a body shop supply place but you will not be disappointed. Not cheap either but no good paint ever is.
Thanks! Looks like you can get it through Amazon for $14
https://www.amazon.com/SEM-39143-Trim-Black...l/dp/B000EM019O. Not cheap, but not bad either. Do you think it would take more than one can to paint everything using this color? IIRC, that would be the parts I mentioned before, plus tunnel access, panels, and parts of the dash panel that were sprayed black at the factory. I just remembered the pedal cluster. Would this be the right color for that as well? Still doesn't seem like a lot of paint.
