QUOTE(Dave_Darling @ Apr 21 2017, 08:56 AM)
Is it just from turning the wheel, or from turning the wheel while the car is moving?
If the former, there's something going on with your steering column. Replacing the bushing in the column might work, or cleaning up and re-lubing or loosening and re-positioning the universal joints in the column. If the latter, the tire is likely rubbing on one fender or the other. Fixing that requires changing tires or wheels, or some work with a BFH or roller.
--DD
It is coming from the column itself. The noise is right there at the column, appears to be up by the steering wheel.
