QUOTE(jmitro @ Apr 22 2017, 07:25 AM)
QUOTE(Dave_Darling @ Apr 21 2017, 11:54 AM)
Note that flipping the bar around front-to-back actually has no effect on the direction of stress through the bar, so getting them in the same orientation that way is not critical.
--DD
if I understand you correctly, I don't see any possible way that is true. the torsional load through the long axis of the bar reverses if the bar is flipped front to rear on the same side
I scratched my head on this one, too. Ended up using a pretzel rod I was eating to prove it out:
Hold the pretzel as though it's the right (pass) side and you're standing on that side of the car. So the rear of the torsion pretzel is in your left hand, front in your right.
The rear (your left hand) is fixed in the cross member. As the suspension compresses, the front, outside twists up (clockwise, if viewed from the front). The rear is held in place but essentially, to counter the twist, it would otherwise have to twist counter-clockwise (if viewed from the rear).
I had to mark my pretzel (?!?!) to note the direction of the twist on each end.
Then I turned it around. Applying the same suspension force causes the same directional twist.
It took me a few times to prove this to myself but I'm with Mr. Darling: So long as you keep the torsion bar on the same side of the car, it's all good.
