JmuRiz
Apr 21 2017, 12:31 PM
WTB: Intake manifolds for 911 Weber 40's with 36mm or 35mm head ports
I have a set of 911 weber intake manifolds that are weber 40 carb in 32mm out.
I'm porting my heads to a larger size for my rebuild.
Anyone have a set of 36mm or 35mm manifolds they aren't using?
I can include my 32mm manifolds as partial trade if interested.
Otherwise I'll have to contact PMO for some of their short manifolds.
Thanks,
Found a set, thanks
stugray
Apr 23 2017, 10:58 AM
I have these, but they are probably what you already have:
There is plenty of meat for opening the outlets by 2mm though
Luke M
Apr 23 2017, 11:14 AM
He's looking for 911 intake manifolds.
I saw a set on pelican yesterday.. 36 mm head 40 mm carb side.
The manifold head side is also for cis heads. I believe you have a 2.7 so these should work for you.
JmuRiz
Apr 23 2017, 11:24 AM
thanks for the tip, I'll look for the set on pelican!
Edit: Looks like it has a power brake booster threaded in it. I'd like to stay away from that seeing as we don't have power brakes, and it'd just upset the airflow a smidge.
JmuRiz
May 3 2017, 10:31 AM
Still looking, wish I would have had the time to go to Hersey this year...I'm sure there were lots to choose from up there.
May 3 2017, 11:25 AM
QUOTE(JmuRiz @ May 3 2017, 12:31 PM)
Parts were scarce this year. Hershey is slowing down. That said, Eric Shea found me some turbo stubs in a mislabeled box PMB rules!
Try earlySreg in addition to pelican. I know most of them want to sell their parts for 2X the going rate but sometimes it works out. Some of those guys have big parts hoards.
JmuRiz
May 17 2017, 09:53 AM
One last bump to see if anyone has 36mm or 35mm intake port manifolds for 911 weber 40 carbs.
If I can't find them soon-ish, I'll fax PMO and see what they have to offer.
mskala
May 17 2017, 10:42 AM
QUOTE(JmuRiz @ May 17 2017, 11:53 AM)
I'm pretty sure I have a set, let me check after work.
kc4ssd
May 26 2017, 12:36 PM
I have a set, send me a pm
Tim
JmuRiz
May 26 2017, 12:42 PM
Whoops, forgot to update my thread, I got a set from mskala the other day.
I'll update, and thanks to all those who responded.
