Finally sprung the car on Monday from TRE Motorsports and wanted to give a shoutout to
@JBCottrell for getting me sorted.
Click to view attachmentThere were a lot of items overlooked or still requiring attention after the drive train went back in. Once the car was in the air, all remaining issues mechanical or otherwise were addressed.
This was the punch list:
Adjust points, dwell & timing
Install rev limiter on distributor
Verify vacuum hose install
Reinstall transmission mounts in correct position
Exhaust leak- replace all 8 Exhaust Studs & take HE for flange welding
Rocker panels secured with correct plated hardware & spacers
Swap steering pan, master cylinder & proportioning valve hardware with plated ones
Clean up previously spliced battery wires & install to new connector
Install correct grommets in rear engine tin
Replace thermostat with NOS unit & cable
Swap incorrect driver side flapper box
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentTook the long way home on a 20 mile run down the 405 Fwy and back across Mulholland down to the Valley. The car drives incredibly well, pulling strong and shifting very smoothly even though all synchros and 1st/reverse slider are new and yet to be worked in.
Click to view attachmentNow need to focus on my ground issue, interior install, final trim fitment and targa trim install.
Getting closer!
