Haven’t posted for the last few weeks, so here is the update:
Was down in OC a few weeks ago and spent the day on electrical trouble shooting (more like trial and error) and solved what was originally thought to be a ground issue on the 4-way flasher circuit. Swapped in a couple of different relays and cleaned the connections where it seats in the fuse box and that did the trick.
Click to view attachmentNext issue: later that week the fog lights and high beams started going intermittent when toggling back to low beams. Correctly guessed this to be a realy issue as well. Shout out to
@mblizzard for hooking me up with a NOS one from a 6 ½ year old FS classified.
Click to view attachmentLesson learned, these little f-ckers fail so always have back up on hand.
Click to view attachmentLast electrical items are to crimp new connectors to the 4 pole door switch and swap out the fasten seat belt light assembly that tested bad. I think the switch may be grounding so ignition buzzer and courtesy light activated by the driver’s side is not functioning as it should. Also need to revisit the green/white wire that connects to the fan control lever. There is another wire connected there and haven’t had the chance to figure out what it is or where it goes, but the fan is not working for sure.
Restored the rear-view mirror by sanding down the trapezoid mount to ready it for new adhesive pad and hit it with Krylon plastic paint. Now good as new.
Click to view attachmentClick to view attachmentSome more shake down runs and miles are up over 300 so it was time to change out the break in oil for some Penn Grade 20W 50. I had been monitoring the oil before every drive and was at the fill line before changing it. Once under the car, realized that it was leaking from the filter. Dodged a bullet there.
Click to view attachmentNext step was to bring the car back to the body shop to revisit the gaps and touch up some boo boos that happened on reassembly. Oil level was perfect after that 75 mile run.
All the rain tray fitment issues stem from the fact that the battery tray is bolted to the quarter panel incorrectly. Tired of this oversight from the first go round so decided to source a NOS tray and support to be welded in and painted. Not the correct way to do it after the drivetrain was reinstalled and mechanicals dialed it, but it is what it is.
Click to view attachmentClick to view attachmentHeat in the rear trunk along with poor prep has caused the paint to bubble up and discolor in the area above where the muffler sits. Solution is to prep and repaint along with installing a thermal absorption pad under the heat shield.
Click to view attachmentClick to view attachmentShould be another week and then its onto the interior and install the targa trim. Rear targa bar has been sanded & polished and ready to re-anodize.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentGetting really close and already looking forward to cooler driving weather in the fall.
